[phpBB Debug] PHP Notice: in file [ROOT]/phpbb/feed/controller/feed.php on line 319: compact(): Undefined variable: forum_id [phpBB Debug] PHP Notice: in file [ROOT]/phpbb/feed/controller/feed.php on line 319: compact(): Undefined variable: mode [phpBB Debug] PHP Notice: in file [ROOT]/phpbb/feed/controller/feed.php on line 319: compact(): Undefined variable: topic_id [phpBB Debug] PHP Notice: in file [ROOT]/phpbb/feed/controller/feed.php on line 319: compact(): Undefined variable: forum_id [phpBB Debug] PHP Notice: in file [ROOT]/phpbb/feed/controller/feed.php on line 319: compact(): Undefined variable: mode [phpBB Debug] PHP Notice: in file [ROOT]/phpbb/feed/controller/feed.php on line 319: compact(): Undefined variable: topic_id [phpBB Debug] PHP Notice: in file [ROOT]/phpbb/feed/controller/feed.php on line 319: compact(): Undefined variable: forum_id [phpBB Debug] PHP Notice: in file [ROOT]/phpbb/feed/controller/feed.php on line 319: compact(): Undefined variable: mode [phpBB Debug] PHP Notice: in file [ROOT]/phpbb/feed/controller/feed.php on line 319: compact(): Undefined variable: topic_id [phpBB Debug] PHP Notice: in file [ROOT]/phpbb/feed/controller/feed.php on line 319: compact(): Undefined variable: forum_id [phpBB Debug] PHP Notice: in file [ROOT]/phpbb/feed/controller/feed.php on line 319: compact(): Undefined variable: mode [phpBB Debug] PHP Notice: in file [ROOT]/phpbb/feed/controller/feed.php on line 319: compact(): Undefined variable: topic_id [phpBB Debug] PHP Notice: in file [ROOT]/phpbb/feed/controller/feed.php on line 319: compact(): Undefined variable: forum_id [phpBB Debug] PHP Notice: in file [ROOT]/phpbb/feed/controller/feed.php on line 319: compact(): Undefined variable: mode [phpBB Debug] PHP Notice: in file [ROOT]/phpbb/feed/controller/feed.php on line 319: compact(): Undefined variable: topic_id [phpBB Debug] PHP Notice: in file [ROOT]/phpbb/feed/controller/feed.php on line 319: compact(): Undefined variable: forum_id [phpBB Debug] PHP Notice: in file [ROOT]/phpbb/feed/controller/feed.php on line 319: compact(): Undefined variable: mode [phpBB Debug] PHP Notice: in file [ROOT]/phpbb/feed/controller/feed.php on line 319: compact(): Undefined variable: topic_id [phpBB Debug] PHP Notice: in file [ROOT]/phpbb/feed/controller/feed.php on line 319: compact(): Undefined variable: forum_id [phpBB Debug] PHP Notice: in file [ROOT]/phpbb/feed/controller/feed.php on line 319: compact(): Undefined variable: mode [phpBB Debug] PHP Notice: in file [ROOT]/phpbb/feed/controller/feed.php on line 319: compact(): Undefined variable: topic_id [phpBB Debug] PHP Notice: in file [ROOT]/phpbb/feed/controller/feed.php on line 319: compact(): Undefined variable: forum_id [phpBB Debug] PHP Notice: in file [ROOT]/phpbb/feed/controller/feed.php on line 319: compact(): Undefined variable: mode [phpBB Debug] PHP Notice: in file [ROOT]/phpbb/feed/controller/feed.php on line 319: compact(): Undefined variable: topic_id [phpBB Debug] PHP Notice: in file [ROOT]/phpbb/feed/controller/feed.php on line 319: compact(): Undefined variable: forum_id [phpBB Debug] PHP Notice: in file [ROOT]/phpbb/feed/controller/feed.php on line 319: compact(): Undefined variable: mode [phpBB Debug] PHP Notice: in file [ROOT]/phpbb/feed/controller/feed.php on line 319: compact(): Undefined variable: topic_id Citroen C3 Picasso ClubКлуб любителей автомобиля Citroen C3 Picasso2026-01-28T22:59:47+03:00http://c3-picasso.ru/app.php/feed/topic/27602026-01-28T22:59:47+03:002026-01-28T22:59:47+03:00http://c3-picasso.ru/viewtopic.php?t=2760&p=266974#p266974Статистика: Добавлено Stayer — 28 янв 2026, 22:59
]]>2026-01-24T12:04:42+03:002026-01-24T12:04:42+03:00http://c3-picasso.ru/viewtopic.php?t=2760&p=266962#p266962Статистика: Добавлено MegaVolt — 24 янв 2026, 12:04
]]>2026-01-24T11:49:14+03:002026-01-24T11:49:14+03:00http://c3-picasso.ru/viewtopic.php?t=2760&p=266961#p266961Статистика: Добавлено darlingg — 24 янв 2026, 11:49
]]>2016-06-30T14:06:15+03:002016-06-30T14:06:15+03:00http://c3-picasso.ru/viewtopic.php?t=2760&p=226508#p226508Статистика: Добавлено NKaado — 30 июн 2016, 14:06
]]>2016-06-23T21:12:18+03:002016-06-23T21:12:18+03:00http://c3-picasso.ru/viewtopic.php?t=2760&p=226169#p226169NKaado, Алексей ! В теме "Фароомыватель" есть фото, как снимать локер. Там фото правого, но разницы никакой нет. Из снимков всё поймёшь. Юниан @ Фароомыватель.
]]>2016-06-23T19:28:35+03:002016-06-23T19:28:35+03:00http://c3-picasso.ru/viewtopic.php?t=2760&p=226165#p226165Статистика: Добавлено NKaado — 23 июн 2016, 19:28
]]>2016-04-14T11:51:33+03:002016-04-14T11:51:33+03:00http://c3-picasso.ru/viewtopic.php?t=2760&p=222749#p222749viv87, от тепла движка она расслаивается. Если шкив люфтит, то будет жрать ремень + в таком состоянии с ним шутки плохи сорвать может, если резину коробить начало.
]]>2016-04-14T11:03:25+03:002016-04-14T11:03:25+03:00http://c3-picasso.ru/viewtopic.php?t=2760&p=222746#p222746Постукивать может ремень приводной, покупал SKF у него место сварки гладкое и чуть ниже на доли мм, чем вся остальная внешняя поверхность ремня. По совету СТОшников, купил Denso - он ровный, все стуки пропали.
]]>2016-02-22T19:15:50+03:002016-02-22T19:15:50+03:00http://c3-picasso.ru/viewtopic.php?t=2760&p=219128#p219128 Полез еще раз смотреть про прижимной ролик и у себя тоже обнаружил, что шкив коленвала не очень ровно крутится. Подстукивающий звук есть, возможно он все таки идет от шкива к.в., а не от прижимного ролика. Решил поменять пока шкив. Думаю подождать до теплых времен.
